Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Export from Plant3D to Robot
4 REPLIES 4
1307 Views, 4 Replies
Hye !
Plant 3D can export structure under .SDNF format.
It seems than Robot is not able to import .SDNF format
Any solution ?
Thanks in advance
4 REPLIES 4
Pawel.Pulak
Please use SSDNF format for file type in the Open Project window of Robot.
Pawel Pulak
Technical Account Specialist
in reply to: Pawel.Pulak
Hi
Thanks, I understood than .SNDF file has to be renamed to .S or .SDF to be readable by Robot.
Pawel.Pulak
Yes, it is necessary to change extension to *.s or *.sdf.
Pawel Pulak
ralph.pullinger
Please watch out for this type of transfer.  I have a feeling that Plant cuts back the members for visualisation purposes which means that the members in RSA will not meet.  Easily corrected if the frame is not too large 🙂 Remember that Plant does not have a concept of analytical lines whereas Revit Structure and AutoCAD Sructural Detailing (to a lesser extent)do.
Structural Techncial Specialist
Autodesk Northern Europe
