Expansion joint simulation
Hi!
Any idea of how i can simulate a expansion joint in Autodesk Robot? The program has any special option for this construction case?
Thank you very much for your answer!
Artur.Kosakowski
Autodesk Support
Autodesk Support
No, there is no special option for this. You may try to use  releases, compatible nodes and elastic supports.
Artur Kosakowski
