Discussion Groups
Robot Structural Analysis
Valued Contributor
bjornhgr
Execution problem no. 3060 in modal analysis
2005 Views, 2 Replies
12-05-2011 12:42 AM
I've modeled a two story building with steel columns, beams, concrete floors and cross bracing. Static analyses, with and without static loads, run perfectly well. However, when I attempt a modal analysis, I get "Execution error no. 3060".
Any ideas as to what might cause this?
Please use plain text.
Product Support
Rafal.Gaweda
Re: Execution problem no. 3060 in modal analysis
12-05-2011 01:21 AM in reply to: bjornhgr
Hi
Usually it is related to ignored instabilities in model.
Correct model to get rid of instabilities.
If it is not the case please update this thread.
Rafal Gaweda
New Member
KONSTANTINOS1982
04-25-2012 06:00 AM in reply to: bjornhgr
Possibly, you would have instability warnings first...that's because of the x bracing middle node is considered to have plane DOF but in "3D" or "Building Module" you add the out of plane displacement where the stiffness matrix becomes 0. Possible solutions...support the out of plane displacement only @ middle x node ...
