i dont know what to do now...
Solved by Artur.Kosakowski. Go to Solution.
the file is to big and when im taking a bit of the model away, i dont get the error. i tried to zip it but its still to big. when the file is unzipt its 27 MB...
Try the following please
1. Open the model that you saved with results
2. Select the bars you that you have the warning displayed for
3. Geometry > Structure > save substructure
4. Save the file, compress it and send it.
LTB verification is carried out only when a flange is under compression. In the demanded verification point the existing tension force (caused by offset applied to the bar) makes both flanges to be under tension instead.
