Hi all,
I tried to install RSA2012 on a desktop computer, and when I launch the program, I always get this error:
Any suggestions?
I got the same error after my 1st installation, this message should disappears after rebooting.
Hello Jad,
I have the same problem all times I start Robot PRO 2012.....we already need a SP???
Bye
Roberto
After rebooting and filling the projects side, this error will disappear
Please confirm us that works or not, thanks.
Hello jad,
unfortunatly even with 4 project on that side I have this error starting robot, after clicking twice on "continua" I can start
Bye
Roberto
A similar effect was observed on Win XP 32bit machines with memory card readers .
Problem could be avoided changing drive letters for the card reader using Disk Management. We have changed from E, F, G, H to K, L, M, N
Problem was not observed on the identical machine, where Win XP 32bit was replaced by Win XP 64bit
Similar problem is discussed there:
http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
Hello jad,
if you consider that I'm using Robot on WIN 7 64bit I think I will continue to click twice on "Continua" button....waiting for a welcome SP
Bye
Roberto
Have you tried the solution up?
Morning all,
I have just installed RSA2013, when I run it I also get the harddisk2/DR2 error message. After clicking continue I get through to the project screen, but when I try to create a new project the software stops working and the Autodesk error report box pops up and the software closes after I have clicked to send the report.
Any suggestions would be appreciated.
Pete
Have you tried that:?
Have changed the drive names but I still can't progress past the project screen
Have you seen crash report window where you can specify e-mail address and report crash? If so please register crash specifying your e-mail address.
Try this: open RC design, if there is no crash please go to Preferences and change OpenGL acceleration, then restart robot and check.
Error report registered and SP2 installed. Still not able progress any further, when accessing a project type it tries to load the model space but then stalls and error report pops up.
THx, we are checking it.
The same if you select RC Element stucture type?
The crash is generated by ATI graphics card driver. PLease update your graphics card driver to the newest one.
Thought I should clarify so that you don't think im trigger happy, I logged two reports, pre and post SP2 install, not sure if that helps.
Yes tried going through RC element structure same result, sorry meant to stipulate.
Thanks for looking into it.
Analyzing them we found that crash is caused by ATI graphics card driver.
Peter,
Try this structure type, Tools \ Preferences, then turn off OpenGL in Robot.
