Dear Mr. Autodesk:
I have a model with some tapered bars and bars with releases and offsets . When i run the analysis, messages of instability errors appears. I've tried to find the solution changing the releases and selecting DSC algorithm in job preferences but the problem is persisting. When I eliminated all the releases observed by the software and run the analysis, the tapered sections were distorted then i closed the file. When i newly opened this file the model didn't showed any distortion in the tapered section but this time an error appeared in the modal analysis. Pleese, maybe you can help me.
Fabrizio
We'll try
Thank you very much for your help Mr. Kosakowski,
I'll follow your instructions and coment to you about the results. Now i'm trying to recover the file because i saved it witout results and now i cannot watch the model in the file. Maybe you can help me if it weren't problem
regards,
WFPG
I'm not sure if I understand you correctly. Is it that you can't see the model in the file you attached to the forum or a new rtd file?
Hello Mr. Kosakowski,
Well, its is possible i have to apply some function of the software because the only image i can watch is showed in the attached
Thanks a lot newly
Regards
WFPG
Try the steps shown on the attached picture.
