Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error unable to find ASMm218res.​dll file
14 REPLIES 14
Message 1 of 15
3182 Views, 14 Replies
Am getting error unable to find ./en-us/asmm218res.dll file.  This is happening when I go to import a autodesk file, the program then shuts down.  Where do I go to trouble shoot this issue?
Thanks Steve
Tags (1)
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
For now workaround:
Copy
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\x64\ROReinf\ASMm218res.dll
to
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US\ASMm218res.dll
Rafal Gaweda
Message 3 of 15
in reply to: Rafal.Gaweda
It happens the same to me,
the procedure is correct, allows to import.
Thanks!!!
Message 4 of 15
tony.ridley
Hi guys,
I get this error when I try to import and cad file (dwg or dxf).
Please advise........
Tony
Message 5 of 15
Message 6 of 15
Hello from Turkey ,
I have a similar problem ,but a little bit different.
I am using spec editor. And I'm gonna add custom part at catalog builder . Consists of a problem at this time.
"Unable to find " error.
Autocad don't find  tr-TR\asmm218res.dll  , so am I.
I can't find tr-TR folder in Program Files.
Also, there isn't Robot structural ...... folder.!!!
Where should I'll find tr-TR folder ?
Tags (1)
Message 7 of 15
Rafal.Gaweda
Strange, there is no tr-TR folder becasue there is no turkish version but, create this folder:
(W7)
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\tr-TR"
then copy contents of
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US"  folder
to this tr-TR folder
Rafal Gaweda
Message 8 of 15
Hello and many thanks !
But, there is not "Autodesk Robot Structural Analysis Professional 2013 " in my Autodesk folder.
I think this is different application for Autocad.
 Where should I create file ? Or  where should I copy this .dll ? Or which "system" folder?
Message 9 of 15
Rafal.Gaweda
I am afraid you have posted your message to wrong forum.
It is Robot forum, not ACAD.
Rafal Gaweda
Message 10 of 15
loubna.lahnin
I have the same problem , but I could'n find the "2013" file I have instead two files "2012" and "2011" , in this two files I coudnt find  "x68" file I have instead " x86". Help plaiiiiiiiiiiiise
Message 11 of 15
Are you talking about Robot 2011 or 2012?
Such file does not exist in these versions at all.
Rafal Gaweda
Message 12 of 15
loubna.lahnin
I have 2013 version, I download it from autodesk website.
Message 13 of 15
Dll file attached
Rafal Gaweda
Message 14 of 15
You sent me a shortcut not the file . Thanks any way Smiley Happy
Message 15 of 15
Sorry, correct dll attached.
Rafal Gaweda
