Discussion Groups
Robot Structural Analysis
Active Contributor
LieberSteve4929
Error unable to find ASMm218res.​dll file
1532 Views, 14 Replies
06-22-2012 01:07 PM
Am getting error unable to find ./en-us/asmm218res.dll file.  This is happening when I go to import a autodesk file, the program then shuts down.  Where do I go to trouble shoot this issue?
Thanks Steve
Please use plain text.
Product Support
Rafal.Gaweda
Re: Error unable to find file
06-24-2012 11:55 PM in reply to: LieberSteve4929
For now workaround:
Copy
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\x64\ROReinf\ASMm218res.dll
to
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US\ASMm218res.dll
Rafal Gaweda
Active Contributor
jorge.lopera
07-11-2012 04:13 AM in reply to: Rafal.Gaweda
It happens the same to me,
the procedure is correct, allows to import.
Thanks!!!
Technical Specialist
Nexsys de Colombia
Valued Mentor
tony.ridley
CAD import error
07-17-2012 07:19 PM in reply to: LieberSteve4929
Hi guys,
I get this error when I try to import and cad file (dwg or dxf).
Please advise........
Tony
Product Support
Artur.Kosakowski
Re: CAD import error
07-17-2012 11:37 PM in reply to: tony.ridley
Active Member
Serdar-C
Error unable to find file (tr-TR)
10-05-2012 05:40 AM in reply to: Rafal.Gaweda
Hello from Turkey ,
I have a similar problem ,but a little bit different.
I am using spec editor. And I'm gonna add custom part at catalog builder . Consists of a problem at this time.
"Unable to find " error.
Autocad don't find  tr-TR\asmm218res.dll  , so am I.
I can't find tr-TR folder in Program Files.
Also, there isn't Robot structural ...... folder.!!!
Where should I'll find tr-TR folder ?
Product Support
Rafal.Gaweda
Re: Error unable to find file (tr-TR)
10-05-2012 05:50 AM in reply to: Serdar-C
Strange, there is no tr-TR folder becasue there is no turkish version but, create this folder:
(W7)
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\tr-TR"
then copy contents of
"c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013\System\Exe\en-US"  folder
to this tr-TR folder
Rafal Gaweda
Active Member
Serdar-C
10-05-2012 06:12 AM in reply to: Rafal.Gaweda
Hello and many thanks !
But, there is not "Autodesk Robot Structural Analysis Professional 2013 " in my Autodesk folder.
I think this is different application for Autocad.
 Where should I create file ? Or  where should I copy this .dll ? Or which "system" folder?
Product Support
Rafal.Gaweda
10-05-2012 06:16 AM in reply to: Serdar-C
I am afraid you have posted your message to wrong forum.
It is Robot forum, not ACAD.
Rafal Gaweda
loubna.lahnin
Re: Error unable to find ASMm218res.​dll file
04-11-2013 01:55 PM in reply to: LieberSteve4929
I have the same problem , but I could'n find the "2013" file I have instead two files "2012" and "2011" , in this two files I coudnt find  "x68" file I have instead " x86". Help plaiiiiiiiiiiiise
