When calculating displacements in Robot using the concrete stiffness I get displacements around 12mm for my SLS-combination. When doing a slab req reinforcement I get 38mm displacement.
Can anyone explain this? Shouldn't the displacment be smaller?
I also get an error message when calculating slab req. reinforcement for panel 152.
Solved by Rafal.Gaweda. Go to Solution.
Thanks!
I've done that and get staisfying results. But, how do I choose the worst SLS-combo, or do I always choose SLS 1?
Error 5000 - are you able to reproduce it?
If so please record movie showing your way.
Try after calcaulation of required reifnorcement save the file, restart robot, relaod the file, run Verification
I understand it have something to do with memory? I'll try to record a later. Construction site is waiting.
I get the error but also get results.
Yes, error 5000 means that memory is overwritten by Robot.
Did this now and the same error came.
