Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error on provided reinforcement
3 REPLIES 3
MohammadZaman
471 Views, 3 Replies
Hello.
I  have modeled and designed a multi storey concrete building.  A had model structure and soil in the same place.
But there is a problem . When I want to transfer an element to provided module, first I can't select simple model . It's button is gray. Next when I run calculation button in provided module nothing happen. I have attached a picture and a file. Could you please help me?
Thank you.
3 REPLIES 3
I have restored the missing relations among simple load cases that the RC Design module needs.
Artur Kosakowski
Thank you . But how do you do this correction?
Next time if I encounter with this problem what should I do?
Artur Kosakowski
