On all library structures I receive an error if i try using them.
What can I do ?
For instants : in the input file ERROR:Syntax incorrect - line ignored
Where can I find a libray of typical structures which are without errors ?
My assumption is that your local settings in Robot are different than the text syntax of the library structure file you want to open. Please try to add Steel to the list of materials in Job Preferences as well as make sure the indicated section databases are declared.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
