Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
error on pre defined structures in Robot Structural Analyse 2011
1 REPLY 1
527 Views, 1 Reply
On all library structures I receive an error if i try using them.
What can I do ?
For instants : in the input file  ERROR:Syntax incorrect - line ignored
Where can I find a libray of typical structures which are without errors ?
1 REPLY 1
Artur.Kosakowski
My assumption is that your local settings in Robot are different than the text syntax of the library structure file you want to open. Please try to add Steel to the list of materials in Job Preferences as  well as make sure the indicated section databases are declared.
Artur Kosakowski
