Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error of using library structure
3 REPLIES 3
643 Views, 3 Replies
Hello.
If I use basic settings -  everything works, but if I switch to:
Regional settings: Eurocode (other languages - english) , I cant insert the objects from library structures. As I apply to insert and object, it always throws me an error (Syntax incorrect).
How can I correctly adjust the settings with english language and eurocode parametres ?
Jonas
3 REPLIES 3
Artur.Kosakowski
What are the materials and steel section databases you have set in Job Preferences (I assume the language as you wrote is set as English)? Please check what sections you have declared by default for the selected library structure (if they are e.g. W change them to European ones or add American section database to the list in Job Preferences).
Artur Kosakowski
Thank you, now it works with Typical structures from Structure Library.
However, i need "Plates and shells". I choose material - Concrete and it does not work. Gives syntax error as well.
Artur.Kosakowski
Try to add Concrete (type its name) to the list of materials.
Artur Kosakowski
