Error of transferring the RC elements
4 REPLIES 4
245 Views, 4 Replies
while transferring the columns to provide reinforcment it gaves me two error how can i solve this
please help me
4 REPLIES 4
teixeiranh
There is some problem with your column.
Can you attach the model or attach a picture of the column that you're trying to transfer?
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
in reply to: teixeiranh
i try any column , the same problem it gives to me
StefanoPasquini6790
Have you used the rc column module to define the section geometry or you have defined it in the generical section builder? Are you sure about the units that you used to define the section (mm, cm, m)? Do you have calculated the required reinforcement? Which are the results...
Try to check all the things that I've suggested you, good luck.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
