Good evening,
how to export the drawings of a rectangular slab from RSA 2012 to ASD 2012?
First, I configured the drawings in robot, then I started ASD 2012 and when I click on the icon "insert drawing from robot" the following error message appears:
and on the command line the following message appears:
then , ASD stop working and an error report is generated
I attached to my message the report files
Help me solve this problem
thank you.
Could you send the rtd file with generated drawing you want to open in ASD and tell what template you use in ASD please?
Hi Artur,
thx for response
I sent the rtd file in question:
http://www.megaupload.com/?d=BU2HXQHF
or
http://www.megaupload.com/?d=M1DLUKQF
NB:
the item is called "dalle1" in the drawing and "radier_30" in the structure.
I dont know how to set up a template, but I'm using the default in ASD ie " RBCR-033.dwt"
thx
Hi Artur,
I was having the same problem and it was fixed with the new version (asd2012sp3_64bit)
Gustavo
REDO, seems like you are one of the last people that managed to use megauplod
Could you tell me which version of ASD2012 you have got installed; is it 64 or 32 bit one?
Hi arthur;
I I rarely use megaupload
I'm usining ASD 2012 64bits under windows 7 64 bits.
can u give me the link for update ASD to sp3 pls?
thx.
HF2 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18343981&linkID=12952913
SP3 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18344170&linkID=12952913
The link to all SPs and HFs
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=12952913
