error of export drawing from RSA2012 to ASD2012
6 REPLIES 6
REDO10
413 Views, 6 Replies
Good evening,
how to export the drawings of a rectangular slab from RSA 2012 to ASD 2012?
First, I configured the drawings in robot, then I started ASD 2012 and when I click on the icon "insert drawing from robot" the following  error message appears:
fatal error
and on the command line the following message appears:
then , ASD  stop  working and an error report is generated
I attached to my message the  report files
Help me solve this problem
thank you.
6 REPLIES 6
Artur.Kosakowski
in reply to: REDO10
Could you send the rtd file with generated drawing you want to open in ASD and tell what template you use in ASD please?
Artur Kosakowski
REDO10
in reply to: Artur.Kosakowski
Hi Artur,
thx for response
I sent the rtd file in question:
http://www.megaupload.com/?d=BU2HXQHF
or
http://www.megaupload.com/?d=M1DLUKQF
NB:
the item is called "dalle1" in the drawing and "radier_30" in the structure.
I dont know how to set up a template, but I'm using the default in ASD ie " RBCR-033.dwt"
thx
Hi Artur,
I was having the same problem and it was fixed with the new version (asd2012sp3_64bit)
Gustavo
Artur.Kosakowski
in reply to: REDO10
REDO, seems like you are one of the last people that managed to use megauplod Smiley Happy
Could you tell me which version of ASD2012 you have got installed; is it 64 or 32 bit one?
Artur Kosakowski
REDO10
Hi arthur;
I I rarely use megaupload Smiley Wink
I'm usining ASD 2012 64bits under windows 7 64 bits.
can u give me the link for update ASD to sp3 pls?
thx.
