I got the error from Robot(see attached picture) - no material for one panel. But the material for this panel is defined(see attached picture) So, what is a problem?
Also I got the warning, that load has not been distributed correctly. After I pushed on this warning, Robot marked all the claddings. So, as I understand, the loads from all the cladings distributed not correctly. But from the picture( see attachment), it looks okey. In the model i have only one clading without generated loads(from other side of the building) So, why all claddings are marked? and why one cladding doesn't have any loads?
no material - run model generation
load distribution - roobt file please.
@Rafal.Gaweda wrote:no material - run model generation
I always thought that when I run calculation, model generation run together automatically.
Rafal.Gaweda, the model attached in my previous tpoic 'load combinations according russian codes'. There I had the same problem with load distribution from claddings.
Yes. But on your screen capture resulst are "out of date" so I do not know what you have done before. Maybe just only local meshing
I will check the file. Have you updated your robot with SP2?
no, i only changed the size of FE for slab(from 1m to 0,5m), to compare the difference of natural frequencies with differenent mesh size.
no, I didn't update it. i'll do it right now.
I do not see any problem.
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Time-to-generate-mesh/m-p/4397001#M16591
remeber - local mesh generation generates meshes only ; it does not apply any property from panel to FEs.
so, you didn't get any warnings about load distribution?
on my computer meshing takes about half of our. computer is really fast. any suggestions what is my problem? may be I need to reinstall robot?
I have forgotten to check it 😞
Meshing time = time of meshing when you run Local Mesh Generation for ALL panels
times of different processes after pressing Run Calculation button (on model without meshes) till starting real caclualtions :
ok, I understood.
Rafal , please, can you check the warning about load distribution on claddings. From horizontal reactions it looks that wind loads applied correctly, but anyway it would be great to start to design the elements without such warnings.
Just not correct verification check.
Need to be corrected by us.
Thx.
I had the same problem and I solve it a different way if it could help:
The material was "disconnected" even if the software says that the panel have a material.
I solve it by overwriting the panel name, and applying again the material and the thickness. (with the exact same name)
Hope it is clear and could help you.
