1. Select a supermember.
2. Right click, select Object Properties.
3. Error message: "Error in the file. Do you want to see them?"
Solved by Artur.Kosakowski. Go to Solution.
1. Do not select a supermember
2. Move the mouse towards it (or its number) so that the supermember is highlighted
3. Press the RMB
4. Select Object Properties
I am not able to get the supermember highlighted. Its number (9000) shows up, but only the component member (521) is highlighted: http://screencast.com/t/uw6lm4gIZn
Switch on display of bar numbers and move the cursor towards 9000 number. When it is highlighted (along with the bar) open its properties. You can also select superbar 9000 before and open it in a new window if you find this easier.
