Error message in reinforcement designer
7 REPLIES 7
Message 1 of 8
Jesper.Jensen
476 Views, 7 Replies
I recieved this error message when running the reinforcement designer in a floor plate model. When I run model verifications there are no problems. Deflections and moments looks fine when reviewing contour maps.
Any idea what this error message means?
Jesper
7 REPLIES 7
Message 2 of 8
Send us model please
Rafal Gaweda
Message 3 of 8
Hi Rafal,
Thanks for the prompt reply. Please use the link below.
http://wtrns.fr/MLmfjn7k4HWYq94
Jesper
Message 4 of 8
It seems it is related to panel thickness 550cm and 700cm.
If you replace them by 80cm it is ok.
Develepers will have to look at it.
Rafal Gaweda
Message 5 of 8
Hi Rafal,
Has someone looked into this as you mentioned?
If you have a look at my attachment, the slab that I'm trying to represent in Robot has a number of steps where a deep beam connects the horisontal slab. This is effectively a wall, but in Robot I have to model the FE panels in the same plane (right) and therefore I have to model them as a slab with a very high structural depth.
When I display my moments the results look OK. The problem only occur when I try to use the reinforcement designer. Is this because the reinforcement designer is only usable up to a certain slab depth? In that case how deep slabs is it ok for?
Jesper
Message 6 of 8
Jesper
From plate and shell theory this panel should be defined as a solid.
No, there is no such limitation in program but developers have to look at the program code to find the reason.
My guess for your reinforcement -> most likely you will get min reinforcement everywhere in these thick slabs.
Rafal Gaweda
Message 7 of 8
Hi Rafal,
Why would it have to be solids and not just am FE wall?
Do you have any illustrations of how a FE slab of floor panels is joined/connected with a wall using solids?
Thanks in advance,
Jesper
Message 8 of 8
Jesper
I said "should".
This is the theory for Robot FEs : http://en.wikipedia.org/wiki/Plate_theory#Kirchhoff.E2.80.93Love_theory_for_thin_plates
If you want to run RC design on this object leave it as panel \ shell. There is no significant bending in it.
Rafal Gaweda
