I just started trying out Robot. I can't seem to resolve an "Error in reading sections data-check the sections database". Any suggestions.
Bill
Bill,
When exactly this message is displayed? The moment you start Robot? Could you make its screen capture and attach it please?
Artur
Re: Error in reading sections data-check the sections database
I get the following error message after:
1. I open Robot
2. Load a project
3. Go to Geometry menu
4. Go to Properties
5. Go to Sections
6. Attempt to open a section selection from the properties database.
Bill
ERROR MESSAGE BELOW:
" See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {5C257DA9-418F-11DF-BDA4-002264AF06AC} failed due to the following error: 80040154.
at DRobotSectLblMngr.frmSectionLabelManager.ComboBox1_TextChanged(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at DRobotSectLblMngr.frmSectionLabelManager.Init()
at DRobotSectLblMngr.Main.MainOnTimer()
at DRobotSectLblMngr.frmTimer.Timer1_Tick(Object eventSender, EventArgs eventArgs)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
RobwinInterop
Assembly Version: 0.0.0.0
Win32 Version: 25,0,0,3774
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinInterop.DLL
msvcm90
Assembly Version: 9.0.30729.4940
Win32 Version: 9.00.30729.4940
CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4940_none_08e4299fa83d7e3c/msvcm90.dll
System
Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
AdWindows
Assembly Version: 3.2.25.0
Win32 Version: 3.2.25.0
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdWindows.DLL
PresentationCore
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.5011 built by: Win7SP1
CodeBase: file:///C:/Windows/assembly/GAC_64/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationFramework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
System.Xml
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/AdApplicationFrame.DLL
PresentationFramework.Aero
Win32 Version: 3.0.6920.4902 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
RobwinRibbon
Assembly Version: 1.0.0.0
Win32 Version: 25.0.0.3774
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/RobwinRibbon.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Autodesk.Common.DOptionSetOrganizer
Assembly Version: 23.0.0.0
Win32 Version: 25.0.0.3756
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/Autodesk.Common.DOptionSetOrganizer.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.Common.DOptionSetOrganizer.Resources
Win32 Version: 23.0.0.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DOptionSetOrganizer/en-US/Autodesk.Common.DOptionSetOrganizer.resources.DLL
Autodesk.Common.DTabControlSelector
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/Autodesk.Common.DTabControlSelector.dll
Autodesk.Common.DTabControlSelector.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Structural/COM/2012/DTabControlSelector/en-US/Autodesk.Common.DTabControlSelector.resources.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Autodesk.REX.Loader
Win32 Version: 2012.0.0.1769
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Loader/Autodesk.REX.Loader.dll
Autodesk.REX.Framework
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.REX.Framework/1.0.0.0__51e16e3b26b42eda/Autodesk.REX.Framework.dll
Autodesk.Common.AResourcesControl
Win32 Version: 2012.0.0.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Common.AResourcesControl/1.0.0.0__ff3304d4f320ee59/Autodesk.Common.AResourcesControl.dll
AREXRobotMngr
Assembly Version: 2012.0.0.1161
Win32 Version: 2012.0.0.1161
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Products/Robot/AREXRobotMngr.dll
Interop.RobotOM
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.RobotOM.DLL
REX.Manager
Assembly Version: 2012.0.0.1769
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Manager.dll
REX.Engine
Assembly Version: 2012.0.0.1422
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Engine.dll
REX.Preferences
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.Preferences.DLL
REX.System
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.System.DLL
REX.UI.WPF
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.WPF.DLL
REX.UI
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.DLL
REX.UI.Forms
Assembly Version: 2012.0.0.1642
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/REX.UI.Forms.DLL
REX.UI.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.UI.resources.DLL
REX.Foundation
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Foundation/REX.Foundation.dll
REX.System.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.System.resources.dll
REX.Manager.Resources
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/Extensions%202012/Framework/Engine/en-US/REX.Manager.resources.dll
DRobotSectLblMngr
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/DRobotSectLblMngr.DLL
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
DRobotSectLblMngr.Resources
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/en-US/DRobotSectLblMngr.resources.DLL
Interop.syspathsLib
Assembly Version: 5.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.syspathsLib.DLL
Interop.IDbRootLib
CodeBase: file:///C:/Program%20Files/Autodesk/Autodesk%20Robot%20Structural%20Analysis%20Professional%202012/System/Exe/Interop.IDbRootLib.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. "
Bill
Bill,
Thank you for this information. Could you tell me what section databases are declared in your Job Preferences? Could you remove all of them but ruser (user section database) and then add them one by one to the list to see if any particular database from the original list is the cause of this situation please?
Bill,
I have assumed you know that you can add a new section using the New Section definition icon rather than Section selection one from the database but then I realized that you actually may not know this so I decided to make this additional post. Of course the question about the list of databases you have got declared is still valid.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Bill,
Please download and install SP1 for Robot 2012 (mind to select the correct version of the pack depending on the version of Robot you have installed) from http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
If you have 64-bit system you will need to install HF2 as well which will be available on this site later today or tomorrow.
