Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
error in equivalent static analysis to EC8
15 REPLIES 15
Message 1 of 16
patkson
799 Views, 15 Replies
Hi all: According to the robot help manual
Base shear force is calculated according to the formula:
Fb = Sd(T1) * m * λ (4.5)
Sd(T1) - value of design spectrum of response for period T1 according to the point 3.2.2.5
m - total mass of the building according to 3.2.4(2)
λ - correction factor, (0.85 or 1.0) set automatically basing on the Clause 4.3.3.2.2
However I notices that the correction factor λ 4.3.3.2.2, is wrongly used by robot. I have done several models making sure that my
T1 is > 2TC (eg 1.6s on type B ground) but robot still uses 0.85 as λ. This result in wrong Total seismic base shear.
The last thing has to do with the value of Ct=0.05 for other structures. I have noticed a typo in the calculation report as the robot still records
a value of 0.09 for other structures this is very confusing. (this has to be corrected)
I will kindly need some clarification on the issues raised above.
Thank you.
pok
15 REPLIES 15
Message 2 of 16
patkson
in reply to: patkson
Hi all is not just NBCC 2010 but also the EC8.
Thank you.
pok
Message 3 of 16
Artur.Kosakowski
What is the number of the stories in your model? Could you attach it?
Artur Kosakowski
Message 4 of 16
dimogrec
in reply to: Artur.Kosakowski
Hi Artur,
I think the answer on your first question is shown in the attached pictures (model 1 ->14stories,  model 2 -> 24stories)
Message 5 of 16
Artur.Kosakowski
in reply to: dimogrec
Thank you - I missed this Smiley Embarassed
Artur Kosakowski
Message 6 of 16
Artur.Kosakowski
As your model seems to have more than 2 stories could you attach it please? Smiley Happy
I have asked the development team to investigate this situation. Thank you for reporting it.
Thank you.
pok
Artur Kosakowski
Message 7 of 16
patkson
Hi Arthur,
I have attached the two models without results as you requested.
And a quick comment, this error is been repeated in the 2015 version.
Please you and your crew should do something about it.
Thank you.
Message 8 of 16
patkson
Test model two
Message 9 of 16
Artur.Kosakowski
Thank you for the files. The issue is under investigation.
Artur Kosakowski
Message 10 of 16
patkson
Hi Artur,
Is getting to two weeks now since I raised the issue above and still haven't heard anything.
Are the team looking into this at all?????
Message 11 of 16
Artur.Kosakowski
The correction is planned for SP2 for Robot 2015.
Please note: Our quality assurance teams may need to reschedule some fixes. Please rely on the above timeline information as a guideline only and not a guarantee. We appreciate your understanding in this matter.
Artur Kosakowski
Message 12 of 16
Corrected in Robot 2015 SP2.
Artur Kosakowski
Message 13 of 16
patkson
ok great I will check it out then..
thx for informing.
Message 14 of 16
patkson
please what's the link to the SP2
Message 15 of 16
Artur.Kosakowski
It will be available in few days under this link.
Artur Kosakowski
Message 16 of 16
patkson
Oh yes is been indeed corrected. Kudos to the RSA team. this phenominal!!
