Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error: Faces not used in solid area generation.
6 REPLIES 6
TorgrimO
4396 Views, 6 Replies
Error: Faces (The objects without assigned thickness) not used in solid area generation. FE mesh has not been generated.
What does this error mean? It is on a cladding with distributed load. Only one of the claddings in my model shows this behaviour.
6 REPLIES 6
Artur.Kosakowski
in reply to: TorgrimO
Do you have any load defined on this cladding? If no, try to add one.
Artur Kosakowski
TorgrimO
in reply to: Artur.Kosakowski
Yes I do. According to the load distribution plots, it looks fine though.
Artur.Kosakowski
Attach the file please.
Artur Kosakowski
TorgrimO
Attached.
Edit by request
Discussion_Admin
Artur.Kosakowski
Is it the right file? I can't see any such warning.
Artur Kosakowski
TorgrimO
Well, I guess it solved itself then. 🙂
