Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Error 5000 incorrect data
12 REPLIES 12
Message 1 of 13
775 Views, 12 Replies
hi , when i export from revit to robot and start analysis the robot get me the error 5000
i hope to tell me the selution for this problem
this is the model for hospital
12 REPLIES 12
Message 2 of 13
Romanich
Do you use x86 Robot?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 13
yes my windows is 7 86x
and this is my model for hosbital i exoprted it from revit structure
i have the same error
my laptop is dell core i7
Message 4 of 13
Romanich
First of all you should check your model for inaccuracies:
Second, you should think to upgrade to Windows x64 - Robot 2015 exist only as x64 application. I have not got error 5000 on Robot 2014 x64 with your model.
Roman Zhelezniak
Message 5 of 13
in reply to: Romanich
first of all , thanks for you
second  for  the model inaccuracies , i prepeared it on revit structure 2014
and how i can check my model on robot
and for windows 64x you think it is better than 86x ?? and the robot 2015 is better than 2014
i will try to change my windows to 64x to see what different and i will install the robot 2015
Message 6 of 13
thanks for you
i did as u tell me but i install robot 2014 64x and the error is disappear >> but really this is the first time i used this program
so if you can tell me how i can solve the first request from you about the iccurecentis
thanks for you
Message 7 of 13
Rafal.Gaweda
Message 8 of 13
senmarecsoubra
i have an error message when i run the attached file (Error 5000 incorrect data)
can you please help me to resolve this problem
thanks
Message 9 of 13
senmarecsoubra
thanks
Message 10 of 13
Try to open the file in the repair mode.
Artur Kosakowski
Message 11 of 13
senmarecsoubra
thanks
Message 12 of 13
senmarecsoubra
thanks
Message 13 of 13
thanks it's work
