Discussion Groups
Robot Structural Analysis
Valued Mentor
tony.ridley
Equivalent static analysis.
385 Views, 5 Replies
09-24-2012 06:15 PM
Hi again,
When using equivalent static analysis for EQ to AS1170.4, why can't you use the results in a combination with non linearity (ie a non-linear combination, or one that includes non-linear member properties i.e. tension only)?
I'm thinking that the equivalent static analysis does not work correctly for models with non-linear members.  Please correct me if I'm wrong.
Cheers,
Tony
Please use plain text.
Product Support
pp2008
Re: Equivalent static analysis.
09-25-2012 12:16 AM in reply to: tony.ridley
Hi Tony,
you are right - components from equivalent static analysis are ignored in non-linear combinations :smileysad:.
Escalated to dev team. I will notify you after change.
Pawel Pulak
Valued Mentor
tony.ridley
09-25-2012 06:40 AM in reply to: pp2008
It's important because you obviously need to add the lateral load to the gravity cases.  It's a bit useless otherwise.
Tony
Product Support
Artur.Kosakowski
03-27-2013 06:47 AM in reply to: tony.ridley
Introduced in SP4 for Robot 2013. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
Valued Mentor
tony.ridley
04-09-2013 08:49 PM in reply to: Artur.Kosakowski
Robot 2103?
I will be doing spectral analysis by telepathy by then :smileytongue:
Product Support
Artur.Kosakowski
04-10-2013 12:21 AM in reply to: tony.ridley
Corrected  :smileyhappy:
Artur Kosakowski
