Equivalent static analysis.
5 REPLIES 5
tony.ridley
703 Views, 5 Replies
Hi again,
When using equivalent static analysis for EQ to AS1170.4, why can't you use the results in a combination with non linearity (ie a non-linear combination, or one that includes non-linear member properties i.e. tension only)?
I'm thinking that the equivalent static analysis does not work correctly for models with non-linear members.  Please correct me if I'm wrong.
Cheers,
Tony
5 REPLIES 5
Pawel.Pulak
in reply to: tony.ridley
Hi Tony,
you are right - components from equivalent static analysis are ignored in non-linear combinations :(.
Escalated to dev team. I will notify you after change.
Pawel Pulak
Technical Account Specialist
tony.ridley
in reply to: Pawel.Pulak
It's important because you obviously need to add the lateral load to the gravity cases.  It's a bit useless otherwise.
Tony
Introduced in SP4 for Robot 2013. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
Robot 2103?
I will be doing spectral analysis by telepathy by then 😛
Corrected  Smiley Happy
Artur Kosakowski
