Dear Sir
first question
Kindly find attached file
http://www.4shared.com/zip/TcRbjMkQ/Robot.html
i have model with seismic ( equivalent lateral force model )
when i checked effective seismic weight from calculation note :
W =52167607 KG
but total mass ( result-advance-model analysis) =32063407 kg
secand question
i have to know when i insert load to mass conversion i choose add mass to global mass or
model or dynamic mass
Best Regards
Solved by Artur.Kosakowski. Go to Solution.
Could you upload the file on another service please? I'm not able to download it. Thank you.
In the current version of Robot it is not possible to exclude density from being taken into account for the Lateral force method (see http://forums.autodesk.com/t5/Autodesk-Robot-Structural/NBCC-Seismic-Equivalent-Static-Method/td-p/3...
In your model the self weight for the lateral force method is doubled (one time being included automatically and the other time as converted case 1) whereas for the modal analysis it is taken into account only one time (from the conversion of case 1).
In the current version of this Robot how i can insert only self weight for part of structure to mass conversion in dynamic analysis i see it include all self weight automatic to mass in seismic analysis+load to mass conversion in calculate base shear
If you mean the response spectra analysis then mark disregard density in the modal analysis parameters, create a load case that contains self weight for selected part of the structure only and convert it into the mass.
The seismic analysis in Robot is based on the response spectra approach. This type of analysis and the spectral one are the same in their principles.
Is this the analysis you mean writing dynamic seismic analysis ?
Which of these two self weight cases should include the whole model and which should be converted for dynamic analyses?
dear sir
kindly find attached file
1- i define two self weight for top and bottom like your photo ( sw on part of model.png )
2- i insert only self weight for top to load to mass conversion
regars
The value in the calculation note in Robot 2013 incorrectly includes self weight but the mass used for calculations is correct. The value in the note has been corrected for Robot 2014.
The option of neglecting self-weight for this type of analysis was introduced RSA 2020.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
