I have a question regarding modeling of moving cranes.
Let EOC1 and EOC2 be two moving cranes. EOC1 generates a concetrated force of 100kN. EOC2 generates a force of 200kN. Their dimensions are identically.
These two act simultaneously on a 2 bay beam.
I defined two load cases, one for moving load given by EOC1, and one for the moving load given by EOC2.
Both have the same line as a route, and the same step.
I then created a manual combination between the moving load cases. This generated all posible combinations of the cranes in all possible positions.
First of all, could it be possible to eliminate combinations where EOC1 and EOC2 are in the same position, as in reality this would not be possible. Can Robot take into account the vechicle dimensions and generate combinations that do not imply overlapping of cranes?
Secondly, in reality, on site , there will always be EOC1 followed by EOC 2, not EOC2 then EOC 1 moving along the beam. So I would have to exclude this combinations also. Can this be done ?
Thank you
There is no automatic solution you could use. I would try the following approach:
1. Definition of EOC 1 moving load and generation of the positions of the vehicle
2. Conversion of these positions into simple load cases
3. As the entire beam has go 12 m in length and the declared step is 1 m I would create 10 EOC2 moving load cases. The first one from 0m till 11m, followed by 0m to 10 m.... the last one from 0m to 1m.
4. Definition of load combinations with simple load case EOC1 at 12m with EOC2 moving load from 0m till 11m; simple load case EOC1 at 11m with EOC2 moving load from 0m till 10m and do on.
Thank you for your answer Artur
This will work for the given exemple.
However the example I gave was a simplification of my real task, in which I have a 75meter long multi bay runway for 3 moving cranes.
All cranes (at one end) have 4 forces (two vertical and two horizontal).
You can imagine that even a semiautomatic forces deffinition approach on the real task implies tousends manual defined load cases, as I need to keep the step at 1m.
Perhaps a more detailed module dedicated to moving cranes / loads could be on the wishlist for future Robot improvements.
