Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Envelope Results
7 REPLIES 7
Message 1 of 8
Mohammed_Ata
1622 Views, 7 Replies
Envelope Results
When i get the reactions of supports , RSA shows the results for all cases and combinations . I defined about 28 combinations . I go to envelope tab and RSA shows the max&min reaction on each support and shows it with different color (as shown in the attached picture) . How can i select the max reactions only (for each support) and copy them ?
7 REPLIES 7
Message 2 of 8
Hi Mohammed,
You can do it in this way:
1) export the envelope table to excel csv file,
2) open on on excel and using find and replace command remove the envelope marker ("<<", ">>"),
3) Use Excel formulas ("max" and "min") to search the values you want.
Otherwise you can use directly the project octopus and create a spreadsheet that automatically do this for you. It depends if you need this tool only one time (i suggest to use the first item) or you use this tool often (in this case I suggest to use the second item)
Good luck, greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 8
What is octopus ?
Message 4 of 8
Jade_Cereno
in reply to: Mohammed_Ata
It's an API used to read RSA results to excel for much better interpretation
MIT-BsCE
Message 5 of 8
Rafal.Gaweda
Message 6 of 8
Mohammed_Ata
in reply to: Rafal.Gaweda
isn't there any existed API that helps me doing this ?
Message 7 of 8
Rafal.Gaweda
What is wrong with Stefano's approach in message 2 ?
You can also:
Filter this table to one particular node , switch to Global Extremes tab, save it or print it or copy it or make screen capture.
Repeat this action for every node you want.
Rafal Gaweda
Message 8 of 8
Mohammed_Ata
Thank you , i already solved it .
By trying editing settings , right click on the results >> special filter >> Extremes >> uncheck all Envelopes options . It shows me only max&min for what i want .
Thank you .
