When i get the reactions of supports , RSA shows the results for all cases and combinations . I defined about 28 combinations . I go to envelope tab and RSA shows the max&min reaction on each support and shows it with different color (as shown in the attached picture) . How can i select the max reactions only (for each support) and copy them ?
Solved by Mohammed_Ata. Go to Solution.
What is octopus ?
Thank you , i already solved it .
By trying editing settings , right click on the results >> special filter >> Extremes >> uncheck all Envelopes options . It shows me only max&min for what i want .
Thank you .
