Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Envelope diagrams
3 REPLIES 3
tigrouis
1684 Views, 3 Replies
Envelope diagrams
I have 20 loading cases including compinations and i whise to examine the envelope of only 5 of the above cases.
How does Robot do it
Thank you
3 REPLIES 3
Rafal.Gaweda
in reply to: tigrouis
Select more than one case
Rafal Gaweda
in reply to: Rafal.Gaweda
In a floor plate model using panels I'm trying to read the bending moment from an envelope defined as above using Results/Maps. Is it possible to seperate the Min/Max results from the envelope so the contour plots become useful.
Case 1: Plot Envelope_Max
Case 2: Plot Envelope_Min
I'm aware it can be done by manually modifying the contour limits under "scale", but this easily become quite time consuming and I'm sure there's a way of isolating the max/min effects?
Thanks in advance,
Jesper
Artur.Kosakowski
There is the devoted option for this:
Artur Kosakowski
