Discussion Groups
Robot Structural Analysis
Active Contributor
sedefass
Envelop problem
395 Views, 4 Replies
11-01-2012 12:17 PM
When I select some of my combinations RSAP should make an envelop diagram, but it does it just for the simple cases, not for the combinations.
Please see the attached pictures.
Thank you in advance
Please use plain text.
Product Support
Rafal.Gaweda
Re: Envelop problem
11-02-2012 01:17 AM in reply to: sedefass
Please send us the file.
Rafal Gaweda
Active Contributor
sedefass
Re: Envelop problem
11-02-2012 07:22 AM in reply to: Rafal.Gaweda
Here is the file.
Product Support
Rafal.Gaweda
Re: Envelop problem
11-05-2012 02:37 AM in reply to: sedefass
It seems the reason can be combination type 2SM for comb 23 24.
IN the attached corrected file the envelopes are generated for all combinatinos except 23 and 24 ;
23 and 24 are also not taken into account for any envelope generation.
If you change them onto CQC or SRSS everything will be fine (another file attached).
Rafal Gaweda
Active Contributor
sedefass
Re: Envelop problem
11-05-2012 10:58 AM in reply to: Rafal.Gaweda
Thank you very very much! Now it works just fine!
