Discussion Groups
Robot Structural Analysis
Valued Contributor
46 Kudos
Re: EN 1990:2002 code combinations
02-13-2013 07:33 AM in reply to: Artur.Kosakowski
Please find attached.
For example, the nº 14 (ULS/1) is leading the LLEnº2 (or LLEnº11) and the LLH nº13 goes with 1,5.
Thanks.
Product Support
760 Kudos
02-14-2013 12:29 AM in reply to: aruser
Still I can't see any problem. I have reduced the number of load cases so that the combinations in question are generated but in the manageable number. See the attached picture.
Artur Kosakowski
