Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Element tags - Move
7 REPLIES 7
Message 1 of 8
AlexDT
484 Views, 7 Replies
Element tags - Move
Can I move element tags? I am able to  drag result- loadlabels, but not tags... they are highlighted when I hover over them though
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: AlexDT
Press the RMB and select 'Select". Move the cursor over the tab so that it is highlighted. Press the LMB and move the tag.
Artur Kosakowski
Message 3 of 8
AlexDT
in reply to: Artur.Kosakowski
haha I hate it when the solution is so simple haha.
In my opinion handling the tags/labels should be similar! ... thats why I didnt think of this I guess.
Thank again Artur!
Message 4 of 8
Artur, Is there a way to move labels from panel cuts?? And also , still on panel cuts , any way of having more values for a single cut ,other than dividing the original cut in several other cuts? Right now ,labels shown are just max/min wish list?? 🙂
Rafael Medeiros
Message 5 of 8
Rafal.Gaweda
in reply to: Rafacascudo
Unfortunately it is not possible to move panels cuts labels.
More values you can see if you make diagram analysis.
Rafal Gaweda
Message 6 of 8
In addition when you click on the 6.11 value field and then move the cursor over the diagram you will be able to check the value s along the cut moving it right and left.
Artur Kosakowski
Message 7 of 8
Artur and RG_Adsk , Yes I know about the diagram analysis capabilities. They´re great!! But I´m talking more about printouts. It would be great if we could have a large slab or wall with several cuts shown in the same screenshot with their local extremes(more than 2 if aplicable) . And for that it would be great( or necessary) to be able to move the labels.
Rafael Medeiros
Message 8 of 8
Added to the wish list.
Artur Kosakowski
