Can I move element tags? I am able to drag result- loadlabels, but not tags... they are highlighted when I hover over them though
Press the RMB and select 'Select". Move the cursor over the tab so that it is highlighted. Press the LMB and move the tag.
haha I hate it when the solution is so simple haha.
In my opinion handling the tags/labels should be similar! ... thats why I didnt think of this I guess.
Thank again Artur!
Rafael Medeiros
Unfortunately it is not possible to move panels cuts labels.
More values you can see if you make diagram analysis.
In addition when you click on the 6.11 value field and then move the cursor over the diagram you will be able to check the value s along the cut moving it right and left.
Rafael Medeiros
