Discussion Groups
Robot Structural Analysis
Valued Mentor
HoshangMustafa
Elastic ground bar definition
700 Views, 8 Replies
01-24-2013 06:50 AM
Hi
Why is the unit of Kz set to kpa? Isn't it kpa/m
If I got a bearing capacity of 10ton/m2, how much will be Kz?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Elastic ground bar definition
01-24-2013 07:25 AM in reply to: HoshangMustafa
Force needed to move a unit length of a bar by the unit of displacement.
KZ is not the same as bearing capacity.
You can use the KZ calculator to estimate this value based on the properties of soil.
Artur Kosakowski
Valued Mentor
HoshangMustafa
Tie beam on ground
01-24-2013 08:56 AM in reply to: HoshangMustafa
Hi
How can i model Tie beam on ground?
Should I use elastic ground bar or Bar with linear support?
Product Support
Artur.Kosakowski
Re: Tie beam on ground
01-25-2013 12:05 AM in reply to: HoshangMustafa
A linear support is not applicable for bars. You should use a bar on elastic ground instead.
Artur Kosakowski
Valued Mentor
HoshangMustafa
01-25-2013 08:43 PM in reply to: Artur.Kosakowski
Thanx
Accept as answer
Valued Mentor
HoshangMustafa
01-25-2013 10:58 PM in reply to: HoshangMustafa
Hi
how can I combine two continuous footing into one continuous footing if the spacing between them is very small or overlapped each other?
Product Support
Artur.Kosakowski
01-27-2013 11:14 PM in reply to: HoshangMustafa
Could you make a sketch that illustrates this situation?
Artur Kosakowski
Valued Mentor
HoshangMustafa
01-30-2013 11:07 AM in reply to: Artur.Kosakowski
Hi
The attached file shows a sketch of a situation of combined continuous footing
I hope you can help solving
Product Support
Artur.Kosakowski
01-30-2013 11:49 PM in reply to: HoshangMustafa
You may consider modeling them as a panel on elastic soil instead.
Artur Kosakowski
