Elastic Foundation with API VBA
14 REPLIES 14
Message 1 of 15
mateaus
1004 Views, 14 Replies
I would like to create an elastic foundation on a element with Robot API in VB.
Have a look to the video please.
Can you give me the code ?
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
in reply to: mateaus
Dim ElasticGroundLabel As RobotLabel
Dim ElaData As RobotBarElasticGroundData
Set ElasticGroundLabel = Robapp.Project.Structure.Labels.Create(I_LT_BAR_ELASTIC_GROUND, "my_ground")
Set ElaData = ElasticGroundLabel.Data
ElaData.KZ = 10000
Robapp.Project.Structure.Labels.Store ElasticGroundLabel
Rafal Gaweda
Message 3 of 15
mateaus
in reply to: Rafal.Gaweda
Ok how can I apply to a element ? for example number 4.
Message 4 of 15
Rafal.Gaweda
Dim Bar As RobotBar
Set Bar = RobApp.Project.Structure.Bars.Get(4)
Bar.SetLabel I_LT_BAR_ELASTIC_GROUND, "my_ground"
Rafal Gaweda
Tags (1)
Message 5 of 15
I would like to create an elastic foundation on a panel (KZ , KY and Kx ) with Robot API in VBA and thank you
Message 6 of 15
Message 7 of 15
Hi
Message 8 of 15
Hi @bensalahsayf.edd
Not implemented in API.
Rafal Gaweda
Message 9 of 15
Thank you , But have you another solution ?
Message 10 of 15
Use planar support instead.
Rafal Gaweda
Message 11 of 15
I used but is not the same result 😞
Message 12 of 15
Hi
Message 13 of 15
It is not implemented in API so it does not matter which language You C++, C#, VB, VBA, Python, Dynamo etc.
Rafal Gaweda
Message 14 of 15
Okey and thank you
Message 15 of 15
Hi Rafal Gaweda
How to define nodes in loads and thank you 
Tags (1)
