Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 8
NSoccolini
542 Views, 7 Replies
Editing Walls
If I draw a wall in my model and after I want to change the position on one of its two extremes, (keeping the other in the same position) Robot automatically moves the whole wall parallelly to itself. How can I solve the problem?
Thank you
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
in reply to: NSoccolini
Message 3 of 8
NSoccolini
in reply to: Rafal.Gaweda
I am working on the 2D XY plan and Robot doesn't allow me to modify the direction of the wall, but it drags the wall parallelly to itself.
Thank you
Message 4 of 8
Rafal.Gaweda
I do not understand.
Movie how it works : http://screencast.com/t/CIHn47IBoq
Rafal Gaweda
Message 5 of 8
NSoccolini
If I look at a vertical wall from the top, that is shown as a line. If a select the line I can edit the wall with a left click of the mouse. My problem is that if I want to change the position of only one of the 2 extremes of the line  (wall), I can't do it because Robot moves the whole line (wall) in a parallel position to the previous location of the line (wall).
Message 6 of 8
Rafal.Gaweda
Message 7 of 8
NSoccolini
Thank you. But other times it was possible to edit a wall manually, by moving its extremes points manually and using the snap option to other points, without typing any coordinates.
Message 8 of 8
Rafal.Gaweda
Not a wall, panel.
Rafal Gaweda
