editing slab contour geometry?
4 REPLIES 4
ovedmata
3859 Views, 4 Replies
What is the easiest way to edit a slab contour geometry? I need to extend the perimeter of the slab 11 1/2 inches to the outside, but when i select the contour defenition under the geometry section of the panel i have to edit the geometry a coordinate at a time. Even when i try I can't get the result i want. Any suggestions?
thank you,
Oved
4 REPLIES 4
Romanich
in reply to: ovedmata
Hello, try to look here - http://goo.gl/zZgNd
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
The another possibility is to select the panel and press the right mouse button. After selecting Object Properties you can change the coordinates of the points that define the contour you want to edit.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
o.elnagar
You can do this by adding a control point at the point where you want to edit the slab. This can be done by:
1) Adding a line (Geomtry>Objects>Polyline-Contour..) then chose a line and draw it over the slab in Plan mode as opposed to 3D
2) Draw the line and select both the slab and the line then choose intersect comand in Edit menu
3) Now you have the intersection
4) Delete the line
5) You will have a control point at the slab which you can move freely
Romanich
You may also consider this approach (using the Spider Pro add-in https://apps.autodesk.com/RSA/en/Detail/Index?id=964813656627065816&appLang=en&os=Win64😞
https://youtu.be/gSvcnQ46WBs?t=51
Roman Zhelezniak
