In order to create envelope diagrams, I'm about to create separate load cases for each span of a 30-span bridge and both symmetric and asymmetric loads. Is there a way to edit the load cases i excel, or do I have to create them all in Robot?
Thank you!
@bjornhgr Artur Kosakowski marked Rafal Gawenda's post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Solved by mgaafar. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Hi
I've recently started using Excel with Robot and I'm really thankful for these small excel-programs you've created Rafal. I am however trying, using your (Rafal's) scripts as models, to modify a program more suited for my needs. One of the things that I can't get to work, when it comes to importing and updating load records, is applying the same load to several bars at ones (I'm creating a program using Uniform loads). The importation to Excel works, but I can't later on update the same cell into Robot. Does anyone have any ideas how to do this?
Thankful for answers
Best regards
Jack
Have you tried doing this? following variable names from API tutorial...
Dim rec As IRobotLoadRecord
rec.Objects.AddText (Cells(xxx, yyy).Value)
At cells(xxx, yyy) you should have all the bars that you want the load to be applied like 1to10 or 2 3 4 7 10...
Of course this will add to already aplied bars... if you want only the bars selected in excel, you will have to exclude that objects first.
Regards
have you tried, for example:
CaseCol.Get(j).Name
CaseCol.Get(j).Nature
of course nature will be 0 - permanent, 1 - exploatation, 2 - wind and so on.
Regards
I was trying to copy the loads from the loads tab table to excel and edit it and paste it back in to ROBOT.
it seems there is a bug because it does not read back the data properly and mixes cells.
am i doing something wrong or it is a bug?
video link:
This Excel-macro is awesome.
Add this if you want to be able to input different SLS-types:
ElseIf ctn = "sls:chr" Or ctn = "SLS:CHR" Then CT = I_CBT_SLS_EC_RAR ElseIf ctn = "sls:qpr" Or ctn = "SLS:QPR" Then CT = I_CBT_SLS_EC_QPR ElseIf ctn = "sls:fre" Or ctn = "SLS:FRE" Then CT = I_CBT_SLS_EC_FRE
Or maybe something like this is better then you don't have to worry about lower/upper case.
If LCase(ctn) = "uls" Then CT = I_CBT_ULS ElseIf LCase(ctn) = "sls" Then CT = I_CBT_SLS ElseIf LCase(ctn) = "sls:chr" Then CT = I_CBT_SLS_EC_RAR ElseIf LCase(ctn) = "sls:qpr" Then CT = I_CBT_SLS_EC_QPR ElseIf LCase(ctn) = "sls:fre" Then CT = I_CBT_SLS_EC_FRE ElseIf LCase(ctn) = "acc" Then CT = I_CBT_ALS End If
Hi
First off thank you for this, the tool is great! And for the standard cases this works perfectly but I can't seem to implement the additional SLS cases.
The macro creates all of the cases and I can review the results for the SLS:CHR/FRE/QPR cases and can see them in the Combination Table however the type is blank. The combination interface is also blank so can't change the type manually and the design modules do not recognize them as SLS combinations. Has anyone implemented this successfully?
Section of code below in case there are any obvious errors that I have overlooked
If ctn = "uls" Or ctn = "ULS" Then CT = I_CBT_ULS ElseIf ctn = "sls" Or ctn = "SLS" Then CT = I_CBT_SLS ElseIf ctn = "acc" Or ctn = "ACC" Then CT = I_CBT_ALS ElseIf ctn = "sls:chr" Or ctn = "SLS:CHR" Then CT = I_CBT_SLS_EC_RAR ElseIf ctn = "sls:fre" Or ctn = "SLS:FRE" Then CT = I_CBT_SLS_EC_FRE ElseIf ctn = "sls:qpr" Or ctn = "SLS:QPR" Then CT = I_CBT_SLS_EC_QPR End If Dim cmb As IRobotCaseCombination If loads.Exist(n) Then Set cmb = loads.Get(n) cmb.name = name cmb.CombinationType = CT Else Set cmb = loads.CreateCombination(n, name, CT, I_CN_EXPLOATATION, I_CAT_COMB) End If
Ah, thought that might be the case. Thank you for confirming Rafal.
I look forward to when it is corrected.
Hi
Is this excel file limited to 25 basic cases?
I try to use it for a model with 27 basic cases, and on the combinations sheet the last two basic load cases are replaced with the first two "from combinations".
Thank you for a (otherwise) great file!
Let's say it is limited to 25 but You can modify it.
1. On Combinations tab, starting from AA column , cells in 3 and 4 row are wrongly filled \ not filled.
Fill it in similar way as in previous columns (let's say till the end of grey cells)
Example for AA column:
2. Open VBA editor (ALT+F11)
and replace 26 by 52 here:
What about the values? The factors from combinations seem to get written to the same cells as before. I'm not very familiar with VBA so I'm not sure what the change in the code was supposed to do.
Yes, I can see the problem now. When I'm using load combinations as basic load cases as well as having 27+ basic load cases, the factors from load combinations get written to the same columns as the last basic load cases.
Maybe I'm asking for too much, but do you know any way to make the xls file adaptive to the number of basic load cases imported?
