I'm having problems with deflection results for the attached model. This is a flat slab with RC walls to one site. Deflection results along this edge for slab are different to wall results , ie: 3-5mm for slab and ~80mm in the wall. How do I need to define/combine these elements so that they 'work together'?
I attach the pdf explaining my question. Thank you very much in advance.
Solved by Artur.Kosakowski. Go to Solution.
The deflection is in the direction perpendicular to the panel. I think you should compare global displacements instead.
