Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Edge deflection
2 REPLIES 2
323 Views, 2 Replies
Edge deflection
I'm having problems with deflection results for the attached model. This is a flat slab with RC walls to one site. Deflection results along this edge for slab are different to wall results , ie: 3-5mm for slab and ~80mm in the wall. How do I  need to define/combine these elements so that they 'work together'?
I attach the pdf explaining my question. Thank you very much in advance.
2 REPLIES 2
Artur.Kosakowski
The deflection is in the direction perpendicular to the panel. I think you should compare global displacements instead.
Artur Kosakowski
in reply to: Artur.Kosakowski
Thanks!
