Discussion Groups
Robot Structural Analysis
esuffk
dynamic response factor
576 Views, 3 Replies
11-07-2012 09:53 AM
I must admit I am very much a novice when it comes to dynamic response analysis.
Are you able to provide me with a walktrhough for obtaining response factors for a continuous slab supported on a series of simply supported beams.  SCI P354 would be the relevant code.
Your help is much appreciated.
Kind Regards,
Andrew
Please use plain text.
Product Support
pp2008
Re: dynamic response factor
11-08-2012 01:16 AM in reply to: esuffk
Hi Andrew,
Have you tried to define footfall analysis selecting  SCI P354 code?
Help topics describing footfall analysis can be very useful.
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
esuffk
11-08-2012 06:08 AM in reply to: esuffk
I have had a look at the help topics but am still a little in the dark.  I cam obtain dynamic response factors for a slab but not for steel beams.  does this require modal analysis ?  how would I go about obtaining response factors for the steel beams?
Many Thanks
Product Support
pp2008
11-08-2012 08:11 AM in reply to: esuffk
If you model a slab together with the beams and FE mesh of the slab is coherent with these beams then they are connected.
In such case response factors for any node along the beams correspond to both the slab and the appropriate point of the beam.
Pawel Pulak
