Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Dynamic degrees of freedom error
10 REPLIES 10
Message 1 of 11
nvgeirinhas
1941 Views, 10 Replies
I have a structure, but when I run the calculations I have this error: "Number of dynamic degrees of freedom equals 0"
I think that is related to the application of the earthquake.
I can't solve it. Any suggestions?
Best Regards
10 REPLIES 10
Message 2 of 11
Most likely you defined supports in all nodes or you set 'disregard' density in the parameters of  the modal analysis without making any load to mass conversion. Otherwise I need the model to check.
Artur Kosakowski
Message 3 of 11
Hello
My parameters on modal analysis are this. Whow can I send the file to you?
Best Regards
Nuno Geirinhas
Message 4 of 11
Save the file with under a new name with no results and then compress it (*.zip). Then you can attach it to the post.
If it is too large use one of the free web services for file transfer and attach the link to download the file.
Artur Kosakowski
Message 5 of 11
nvgeirinhas
in reply to: nvgeirinhas
I send attach the file.
Message 6 of 11
"Most likely you defined supports in all nodes .."
Divide bars e.g. in this way:
Artur Kosakowski
Message 7 of 11
Hello Athur,
I have the same problem with the "Number of dynamic degrees of freedom equals 0.".
I try to divied the Edge 1 in more elements, but I still have this problem. My objectiv is to find the modal analysis of a dam.
Could you or somebody help me please to solve this issue?
Thanks in advance,
Razvan
Tags (1)
Message 8 of 11
This needs to be addressed by the development team.
Artur Kosakowski
Message 9 of 11
Some workaround may be replacing your plane strain model by volumetric one.
Attached the file where I converted your model to solid - 10 meter slice of the dam modeled, additional face supports added to make it coherent with plane strain constraints.
A have deleted the loads - it will be necesary to re-define them as surface loads.
I have also noticed that you attempted to convert water pressure load into masses. Usually considering the pressure of liquid in vibrations is not so simple - there were some references considering it in some other post on this forum.
Best regards,
Pawel Pulak
Technical Account Specialist
Message 10 of 11
mjoflor
in reply to: Pawel.Pulak
There is no load to mass conversion, it need for modal analysis,
Message 11 of 11
Corrected in SP3 for Robot 2015.
Artur Kosakowski
