As you can see in the attached image in the Dynamic Analysis Results table I don't get more than 90% mass participation in the X direction even though I have defined 10 modes...Do I need to define more modes in order to reach prefered percentage?
Could you please explain what do the titles Rel.mas(%) and Cur.mas(%) of the colums in the DynamicAnalysisResult table mean?
Additionally,I might haven't understood what exactly "sturm check" and "disregard density" do....Please explain in a few words...
Moreover why do I get this notification in steel analysis?
Thanks in advance...
Cur mass is current mass that is participating at each mode.
Rel mass is the cumulative mass added bit by bit from each mode that needs to hit 90% (or whatever number for code requirement).
The steel design message means the angle has not been checked about the weakest axis, but about the principle axis (which depending on the actual geometry may not be possible)
In addition to Tony's answer (thank you Tony )
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Buckling-equal-angles/m-p/3399339
Thank you guys,
what about "sturm check" and "disregard density" in modal parameters?
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-AD28B8C7-F614-4A51-9A8B-2E1FA66D13F6.htm
