hi ,,
I have two question :
1:How do I draw two salb of two different level, where it becomes a simple slab ?
2: How do I create drop panels above the columns ?
Solved by teixeiranh. Go to Solution.
I am not sure if I understand your droughts regarding the slabs. Anyway, I made a small demonstration:
http://www.screencast.com/t/M7wbtHKx5g
Regarding the drop panel, you may do something like this:
http://www.screencast.com/t/fcvfUhTen
Thank you
For my first question, ((the slab Is based on the normal beams )) ...
Must be momente on the edge of the simple slab (( zero ))...
Hum... I don't think that I understand what you are trying ti say...
Could you please attach the rtd model?
I think you mean bathroom and kitchen dropped slabs if i am right you can use linear release to achieve zero moment on the edges.
The drop cap top face elevation is above the slab top elevation, shouldn't it be offset in the -ve z axis so that the drop cap top face elevation aligns with the slab top fac elevation?
