When we select the option: "Double sections treated as solid", when defining the member's parameters in EC5, how exactly Robot handles these sections?
Solved by Artur.Kosakowski. Go to Solution.
The difference is in IX calculations (LTB verification).
Thank you Artur,
So, only the parameter of Ix differentiates (someone can notice that from the calculation note indeed). Which calculation formula is being used to obtain Ix in such cases?
