I am looking around to make Dock Pane (like Navisworks) or Docking Palette (like AutoCAD) in Robot. Like Object Inspector pane in Robot, which is dockable on the left application or we can drag it into a separate window. How can I do it in .NET API. The class RobotApplication does not have enough properties and methods to play around with the docking panel.
Thank you,
Solved by Rafal.Gaweda. Go to Solution.
