Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Divide shell into equal parts
1 REPLY 1
StructuralSilver55
668 Views, 1 Reply
Hi!
I would like to know how i can divide a shell like the selected one
into 3 equal part (for example, to delete the middle one and simulate a window). I tried to use the divide command in edit menu... but it doesn't work.
Thank you very much for your help!
1 REPLY 1
1. Define two lines at the levels of the intended opening's edges
2. Run local meshing of this panel (this freezes the generated mesh)
3. Delete the elements from the opening
or
1. Define the boundary of the opening (contour)
2. Mesh the panel
Artur Kosakowski
