Discussion Groups
Robot Structural Analysis
Product Support
1,303 Kudos
Re: Distorted Elements and Mesh Error
10-03-2012 03:42 AM in reply to: AndyWalker
In a minute I will send you model and explanation.
Rafal Gaweda
Product Support
1,303 Kudos
10-03-2012 04:04 AM in reply to: Rafal.Gaweda
Nodes 4272 4273 should be corrected by Detailed Correct to Line created by nodes  4272 4273 .
Corrected model: http://wtrns.fr/EUYoXQ5P3XsYCiX
Rafal Gaweda
Valued Contributor
0 Kudos
10-03-2012 04:48 AM in reply to: Rafal.Gaweda
That is it.
Thank you very much.
So was this error created due to the meshing creating two nodes that were not exactly on the line?
And it can be corrected using the "Detailed Structure Correction"?
What alerted you to this error or was it just experience?
Andy
Product Support
1,303 Kudos
10-03-2012 05:33 AM in reply to: AndyWalker
Most likely.
As I said, yes.
Experience  :-)!
Rafal Gaweda
