Dear Colleagues
My attached model was running perfectly . But suddenly stopped by " distorted element " message .
Could you help me to know what is the reason for this trouble in my model ?
Note : please , attach any capture for explanation
http://www.2shared.com/file/7kJWkxoY/01_online.html
Thanks in advance for your support
Refaat
Meshig options for cylindrical walls:
File attached.
Dear Rafal
I opened your modified file as you set . but
1. I received instability message as appears in capture 00.
2. As you can see in the second capture 01 , the moment results are illogical .
3. I have noted that Panel sections' definitions and some member elements materials were not transferred from main model to substructure model since this file was saved as substructure " capture 02 ".
Please , help me to solve this problem.
Note : Please , if you use any capture for explanation . please send it as attached .
Refaat
And I think this is the reason of instabilities, please assign materials to panels \ define and assign new panel thicknesses.
